HEMIMANN
- Joined
- Dec 7, 2020
- Posts
- 9,579
- Reaction score
- 25,202
- Location
- Minneapolis, MN
- Ram Year
- 2017 2500 Laramie Crew Cab
- Engine
- 6.4L HEMI
Pretty soon we won't have oil to sample.
I did a 1500 mile run with PUP 0w-20 which i have a sample of to send to OAI from the free sample kit i got for buying it and about 500 miles ago i changed that out for esp x2 0w-20 and ill see how the wear metals come down. Kinda wish i changed at 500 miles like i originally planned to. Young engine though ill look back at other young hemis and compareWhat oil went back in?
Well if you listen to the progressive Mobil is evil lol.. BTW I'll wave Hi at ya when I make the right hand turn at Albert Lea on Sunday, Ill be on my way to Mason City Iowa area to look at a home to buy so I can get away from the kooks here in the Portland Oregon area...News to me - even Mobil Corporate didn't teach us that.![]()
Hmm, can it be the 0w30? Probably not but I'd change to verify. Did you run it back? Now that isn't the SC but just their 0w30? Thoughts on your alum climbing up? Yes better with the 0w30 but still up historically on your uoa's, might hint why iron creeping up. Maybe rings issue? Not sure color code shows the story with 100k difference between samples and one still young engine.
Do you dose fuel and if so with what?
maybe a combo of the winter being harsher and a alightly thinner viscosity? Allthough i have a hard time thinking half a cst would cause that as the additive package is very strong
You do a fantastic job collecting data points so i will be interested to see what happens! Hopefully its just increased from the cold startup this past winter being harsher and allMost wear is during warmup (if I understand correctly). Worth noting that I have one other P+ run a few oil changes back, and that was in the 2-3 ppm/1000 range, in the same months (oct - april) so it may not be the formula at all, who knows. The next 4 runs will be the exact same oil (PCMO 5w-30 instead of P+ 0w-30 in this report) so that should be an interesting test to see if iron jumps down/up at all.
Just seems odd that my best results were the previous OCI on the PCMO 5w-30, which was the summer run, and I definitely work it harder with more towing trips. But startup is on much warmer temps too![]()
I’m running the amsoil signature series 5w30 Wix filter thought about trying some HPL though. 2015 5.7 38,000 milesThis was the Premium Plus; same formula as super car except it uses the API ad pack instead of Euro, but the rest is the same. It's their "top of the line" API blend, super car is their top of the line Euro blend, and then they have 2 simpler blends for each below that.
Aluminum isn't climbing up, all HPL's oils have on average about 3 to 7 PPM right from the virg|n oil, it's part of the moly as explained by David Ward himself. You can see it in this VOA database here too. It comes up a lot on bitog too, throws everyone for a loop. One VOA sample came back at 18 ppm which was an outlier of course, the sampling may have been a little off on that one.
I'm not too concerned about the iron, between 2 to 4 PPM/1000 miles is common for the hemi and other iron block v8s, but yeah I'd like to see it back down to 2 PPM range for sure.
I'm back to their basic PCMO 5w-30 this oil change, and I have another 3 oil changes for this in my garage so the next 4 runs will be interesting to watch.
I do use a fuel cleaner, Redline SI-1, not sure if I had any in there this past run but generally I aim for 1 full bottle in the tank per OCI.
Here's my 22 ram 1500 5.7L (w/o eTorque) horizon oil report at 61k miles.Finally figured out how to create an eoilreports account and get my free sample sent off last week... Hopefully I submitted it correctly.
If I can figure out what to download/post for the report once it's processed, I will share it here and hopefully the oil gurus will be kind enough to tell me what it means!
Thanks again for sharing @Burla and @Travis8352 !
I cant see anything, link?Here's my 22 ram 1500 5.7L (w/o eTorque) horizon oil report at 61k miles.
* Penzoil Ultra Platinum last 2 changes at 6-8k mi ea
... Penz Platinum for prior changes at 30-50k mi
... Dealer did prior oil changes from 0-30kmi.
... PacBrake remote filter setup, using standard Mopar MO-339 filters (since 30k mi)
They claim it's ok/normal... Let me know if anyone sees anything concerning?
Thanks in advance!
Mike G
He linked it in the another thread, or something, scroll down in his postI cant see anything, link?
Right in the middle under "sample information"I don't see the mileage, but the report looks pretty perfect even with that thin oil. The only concern is copper, but my guess is still low mileage so normal at this point.
