blistein 5100 install on 2006 1500
rocket
Licensed Dynacologist
Pennsylvania
was 2006
was a HEMI 5.7
those nuts are nyloned...they will not loosen trust me.(I know mine were)
usaf2006
North Carolina
So don't torque the lower ball joint? Lol how do I know how tight to go?
rocket
Pennsylvania
was 2006
was a HEMI 5.7
That bolt tightens til it stops...when it does it literally pulls the stem of the ball joint into place...needing a fork to separate,even right after installation.....I'd crank it to the highest setting....ya ain't gonna break it.:)
rocket
Pennsylvania
was 2006
was a HEMI 5.7
Can I just install a shim behind the springs without disabling the slipper clutch? I dont plan to drag race the bike, but I dont want a slipping clutch either.
uhhhhh, Your not only on the wrong thread, but the wrong ******* forum:roflsquared:
Hurt-Much
Canada
For anyone who is attempting this I did a video showing what it can take. It should give you a good idea of what to expect in a worst case scenario. Also I HIGHLY recommend torquing everything to the recommended settings and not a bit more. I over tightened my upper ball joint and cracked my steering knuckle as a result and ended up having to replace that.
https://www.youtube.com/watch?v=_vpiKCyoboA
Arturo Rojas
