Blower motor, Now no heat?
2017azlaramie
I had my blower motor replaced over the weekend. I had my neighbor do the job due to recent left arm injury. After the install, there is no heat. The blend door doesn't seem to be moving to heat. The heat worked fine before the motor replacement. I replaced the motor due to erratic operation. Sometimes it worked. And other times it just stopped driving down the road. Now that the temperatures are dropping the heat would be nice to have. Could something be bound up when the new motor went in?
Any help would be appreciated.
Ken226
Washington State
Did you inspect it to make sure nothing was forgotten or broken?
That the blend door connector was reconnected and wasn't damaged?
2017azlaramie
2017azlaramie
No, I have not looked at anything under the dash. Due to an injury. Which is why I had my neighbor do the install. Where is the blend door connector located? In relationship to the motor?
