Canadian_Ram
- Aug 15, 2014
- 181
- 50
- Location
- Alberta, Canada
- 2013
- Hemi 5.7
Okay I'm tuned on 93 HF on a 6 speed RFE with the mods below in my signature.
If I am in the select-able gear mode (slap-shift or triptronic or any other term for it) and I am at WOT my truck will shift at redline 1-2 like butter and sounds like sex doing so.
NOW
If I keep the hammer down (gets kinda hairy and might be going too fast anyways but stay with me) and get to 2nd gear redline It will basically bog and bounce of the redline which is scary and you need to force it to shift up or at least I won't try and find out how long (if ever) it will take to shift on its own.
It also does this 3-4 (don't judge me I am addicted to speed
Anyone else ever have this happen? Should I be concerned or is there some preventative maintenance I need to do or check out in-case there is something larger causing this? Any advice is appreciated so throw it all at me.
NOW
).Anyone else ever have this happen? Should I be concerned or is there some preventative maintenance I need to do or check out in-case there is something larger causing this? Any advice is appreciated so throw it all at me.
