pacofortacos
- Apr 18, 2017
- 3,613
- 4,437
- 2016
- 5.7
Towing and headers are just not a good combination - maybe for short trips but not long distances.
They will be almost glowing after a bit - unless the 5.7 is a lot different than my 5.9 was, the underhood heat was incredible when I had ceramic coated (wrapped in places) headers on my 5.9 dakota, so much so I went back to cast manifolds.
You will never get back the money spent on a tune and most will require 91 or higher octane for any real boost. Again costing more so you aren't saving any $$.
Setting up the truck to maintain the stock rake (front down rear up) while loaded will help on the mpg some, and are the most economical mods to do. This with some underbelly mods gained me 2-3 mpg when towing.
If you have a chrome bumper, at highway speed the black air dam under the bumper will fold back and up at the center of the air dam and let air just ram into the frame under the motor - killing some aerodynamics. Don't believe me, just look at any chrome bumper 4th gen 1500 doing 70 mph coming the other direction and look at the center under the bumper - the vast majority will be folded up in the center. You can also see it if you crawl under the truck and look at the air dam - you will see the crease.
3.92's can help but honestly aren't needed with the 8 speed in most cases as the 3.21 is basically just one gear off of the 3.92's. Ie. - 8th (3.92's) = 7th(3.21's) and this stays true down to about 5th gear.
Just use tow/haul and the ERS buttons.
