RAM0359
Just replaced pads, rotors & calipers for front right and left. Back brake system is all original OEM. Siphoned most of the old brake fluid from the reservoir and put in fresh new dot 3 fluid. bled all four brakes until no more bubbles, pedal woul get hard but as soon as I close the bleeder valve the pedal goes to the floor again. What am I doing wrong. Since I didn't drain all the fluid I tried just bleeding the fronts and no pedal once I started the truck up. When that happened I also tried bleeding the backs with still the brake pedal to the floor.
