Broken Manifold studs
04hemi2500
Got a bad exhaust leak on my tuck. is an 04 2500 hemi. ordered all new exhaust manifolds with hardware and gaskets. I see 3 broken studs already. My question is, has anyone replaced manifolds? anything special i need to know before i start tearing it apart? is it as bad as it looks to do? The bolts and studs that arnt broken are rusty and crusty too. Any info or tips would be a great help.
iSlacker816
Kansas City, MO
5.9 (360ci) Magnum
Soak em down in PB Blaster for a few days before you do them. Before work hit em, get home from work hit em. The more you use on them the easier they'll come out
03MopaRamman
RAM SPORT / 18 SRT
Southern Alberta
2019 (2003 Forgottens SOLD and 2014 SOLD)
Hemi 5.7 (392 Hemi) 86 Ford .308 HO Roller
It needs to be completely cold. Once the manifold is removed you can get at the broken shafts. Once cracked they will come out easy. I am fortunate with where i live, just did my 05 LX Car and only broke 1 heat shield end nut out of nine. My 03 Truck they all came out easy but then again i did it when bone cold. I recommend 6.1 mopar Header bolts as they are of proper length for any application, have a 10mm bolt head and come pre thread locked so no requirement to go back and re-tighten. Also use Factory gasket on any application too. Good Luck.
swamp_life hemi 05
Tallahassee Fl.
2005 laramie
If your in there, might as well replace the manifolds with some shorties ;)
It aint easy.... bein' Easy ;)
04hemi2500
04hemi2500
Thanks for the tips. Was going to do headers but price is an issue and i get oem mopar parts dirt cheap so stock manifolds and oem gaskets and harware is what i got.
05singlecabHEMI
Lilburn,GA
damn, you shoulda let me know before you bought them. I have my manifolds with all the hardware. Would have just gave them to you.
04hemi2500
04hemi2500
well got them off today. Still have 2 broken bolts to drill out of the head and 3 that i can hopefully get extractors on. had to use Oxy acytelyn torch to cut heads of 3 bolts that stripped under the engine mounts. Nightmare job to say the least.
DIPPIN04
I recommend 6.1 mopar Header bolts as they are of proper length for any application said:
where might one buy these 6.1 header bolts, and they fit with no issues?
