Broken Valve Springs
Jason-13581
Baton Rouge
I have a 2013 Ram 1500 5.7 motor was knocking very loud no power took to the shop had it looked at , they found 3 broken valve springs and replaced them , got truck back oil pouring from valve cover , come to find out the valve cover gasket rolled when replacing the valve cover so they fix that , now I have another oil leak that can’t be found , if you get under the truck and rev the engine you can see a fine mist of oil where or what else could be leaking oil ....
Dodge 1500 4X4
Rochester, NY
Maybe oil pressure sending unit? tell us more about broken valve springs and are the valves ok.
