BT Catch Can filled after 2000kms
Ram83
British Columbia, Canada
2014 Ram Sport
just checked my catch can and it was full after 2000km from my oil change..is that bad?
MADDOG
Living in a Firepit
No but I'd check your main engine oil level.
You may have overfilled it?
Ram83
Ram83
2014 Ram Sport
my egine oil level is just a tad under full.
not sure why there was so much oil in the catch can...ill keep a eye on for sure
audio1der
Airdrie, Alberta
It's posts like this that make me wonder if my Moroso is not doing its job?
Hemi450hp
Moe's Performance
Conroe, TX
2014 Ram 1500
Mine is usually 3/4 full in about 2000 miles. I wouldn't be worried about anything, but check it sooner next time so that you dont accidently let it overflow into the intake.
limited
2012 Black Limited 1500
Same here about 3/4 on 2500 miles,
xrsman
Ontario
3.0 Ecodiesel
I think it varies by truck, because my BT catch can takes a long time to fill up too! Definitely not in 2000 kms!
Casper
U.S. Navy (Ret.)
Springfield, VA
5.7L
There is nothing unusual about that kind of accumulation.
It seems like a lot, but it took almost two years to accumulate 20 ounces of funky milkshake from my catch can--and yes, I saved it to see just how much yilch I could keep from gunking up the inside of my intake manifold in response to all the doubters and catch can bashers here on RF. Silly, silly little people.
SlowRoller
Lotsa variables. Oil/NOACK rate, outside temps(water condensation/'milk'),,, etc etc etc.
RedViper94
Upstate NY
I emptied my BT after 1600 miles, was about 1/3 full or 2/3 empty :)
crazy_luck
Minnesota
After 2700 miles, mine was barely 1/3 full. Remember, the PCV system is opened/closed by vacuum pressure - more throttle will keep the PCV closed, limiting the amount of oil that would make it through into the can. Drive it like you stole it, the can will stay empty, drive it like Ms. Daisy is in the passenger seat and that can will be overflowing before the end of the first block....
