Build Sheet - Axle Ratio Question
rwalk
Westford, MA
4.7L V8
Here is a picture of my build sheet on my 2012 Outdoorsman.. Lists both 3.92 and 3.55 rear axle ratios.. I always thought I had 3.92 until I looked at this, how do I know what I really have
Sherpa
1998 TJ
4.0L straight six
First, that's not a build sheet--it's a Monroney label (also known as a window sticker). It shows that your truck was equipped with a package that includes the 3.92 axle ratio. Later on, the 3.55 ratio is individually listed. This makes me believe whoever ordered your truck decided to step down to the 3.55 ratio. If they did this, I would expect it to give you a credit (ie--have a negative price listed). What does your sticker say?
To know for sure what you have, there are three possible methods:
1) Look at an actual build sheet and see what it says
2) Inspect your axle housings for any identifying marks that may be present (assuming Dodge does this)
3) jack up the rear end, rotate the drive shaft and count tire revolutions
HTH
rwalk
rwalk
Westford, MA
4.7L V8
It adds $50 to the price next to the 3.55 ratio. Where would I go about finding a build sheet? I already tried looking on the axle and didn't see anything
albertschmitz
Grimes, IA
shoot me the VIN and I will pull a build sheet for the truck and it will tell you the acrtual ratio for it.
LB3711
Trumbull, CT
3.6L V6
wont it just say right on the axle its self? My 2002 durango did. I haven't looked on my ram yet.
rwalk
rwalk
Westford, MA
4.7L V8
I looked and couldn't see it but I may just be missing it
Sherpa
1998 TJ
4.0L straight six
My Wrangler also says this, but I don't know if the Ram axles do.
rwalk
rwalk
Westford, MA
4.7L V8
Where on the axle did yours say? I can't seem to find any sticker, but there looks like theres a spot where one may have been but fell off, not 100% sure though.
rwalk
rwalk
Westford, MA
4.7L V8
Just filled out the form requesting a build sheet for my truck from Dodge.
LB3711
Trumbull, CT
3.6L V6
I found a pic where it says it. Drivers side of the axle.
You can see mine says 3.55
mattman_13
Mine has a sticker with identifying numbers on it.
rwalk
rwalk
Westford, MA
4.7L V8
I'm leaning towards having 3.55's from what I see online :suicide:
As far as stickers, I'm quite sure mine fell off after looking under there and seeing where it should be
The Crow 1994
Nebraska
Hemi 5.7L w/8 Speed Trans.
I know you have a 2012, but aren't 3.55's standard on the 2013 Outdoorsman trucks? I'm guessing that you have the 3.92's.
UPNO4
Utah
2013 Laramie , 2023 Laramie
Hemi 5.7 8spd, 6.7 CTD
Like I said earlier, just pm me the VIN and I will send the build sheet to you.
Albert
Should just need the last 8 of the VIN if I remember correctly
KAKA
