Bullydog Users
CaliDodgeRam
California
Bought my tuner used off the forum a few months back finally was going to put it in today, didn't have the fuse tap so I ran down to the auto part store and picked some up. I had read the reviews before so I knew to tap into m33, however the fuse taps I bought were too big to fit with the fuse into m33. Any suggestions on another fuse that is larger and on when the truck is? Also how did you run your wire back into the truck through the firewall, the rubber grommet deal is giving me a hell of a time. Thanks!
Lhemi
OKC OK
6.7 Cummins Turbo & Hemi 5.7
The rubber grommet where the main wiring harness goes through the fire wall is where I ran mine. Zip tied everything together so it looks just like factory stuff. It's easy if you stuff a long zip tie through the grommet then tape your wire to it and pull everything through together.
I used a pick and opened the hole up while I was pushing everything through. As for a different fuse I would just use a test light to see what was hot with the key off.
