bullydog
NUKE IT
new jersey
2012 1500 5.7 hemi bully dog gt set-up, red line set at 6000 rpm, shift points at 6000 rpm, max speed set @ 200 !! throttle position @ max sensitivity plus added bully dog thruster for more burn, jet 180 thermostat, mopar cold air intake, moe's catch can, magnaflow exhaust, bilstein 5100 all around, front timbren tdf15004b , hellwig adj sway bars, rear ride rite air bags, drilled rotors all around, 1000 watt inverter, 5w30 castrol edge forever, mds turned off since day one, never a tick ! more junk and a loose nut behind the wheel.
