americanthunder
Just wanted to share my experience with our shiny new 1500 towing our sort of heavy TT. Coming from a 3/4 Duramax I expected things go be a little more "difficult" but as it turns out this 5.7 Hemi paired with the 8spd and 3.92 Gears is a towing machine! No worries about power here. Here is a pic of our setup at camp:
The load: A 2012 North Country Lakeside 29ODK. Tag reads 7400 Dry from the factory. I've added a toolbox on the tongue that contains four GC batteries, 4 solar panels on the roof, and an 2000 Watt Pure Pure Sine Inverter. Loaded with a weekend full of fun I've weighed it in the past and its usually right around 8400 with a full water tank. Tongue weight is right at 980. Im currently using a WD hitch with 800lb bars with dual friction sways.
Cab of the truck contained me, my wife, my son, and our dog. Left the bed empty except for a few small items. Overall we are right at our trucks max payload when factoring the tongue weight which concerned me right off the bat.
The Journey: We traveled from Tucson to the Greens Peak Arizona and back. Basically from around 2600 feet to 9500 feet. Temps ranged from over 100 degrees to the mid 50s during our travels. Plenty of nice long steep grades both coming and going, more going
I prepped in advance by setting up the hitch. I used the the method where you put the truck into "Jack Mode" while I adjusted the bars. The truck was in normal ride height and I was able to get most of the squat out before turning the air back on which leveled the truck right off. Right off the bat I noticed the truck felt very well planted but at freeway speeds any wind or tractor trailer would send me into white knuckle mode as the trailer would start to sway violently taking the truck with it. I stopped on two occasions to readjust the tension on the bars and it appeared that LESS tension and more weight on the truck improved straight line but the front end felt light. Any feedback ya'll can give me here is appreciated!
Ok so I'm still not confident in the handling department and I'll work on that hopefully with the help of everyone here but onto that engine...All I can say is WOW. I don't know how they did it but the trans and engine work in complete harmony. It took me a bit to learn to just let the engine "sing" as I wasn't used to turning those kinds of RPM's but over the course of the trip there was never a moment I felt the truck was underpowered and it held speed up every grade. Coming back down the transmission downshifted and again the engine was singing but very rarely did I need to apply the brakes and when I did, the built in trailer brake controller worked flawlessly. I did have to set it to "Heavy Trailer" mode and right around 7.5 to get just the right feel but I felt confident if I needed to stop I would.
Most of the trip the cruise was set between 55-60 mph as thats as safe as I could feel given the swaying issue. Overall the trip was 537.7 miles and we used a whopping 60.4 gallons of mid grade unleaded. For those math wizards out there thats just under 9 MPG (yea I used a calculator) so the little Hemi is THIRSTY but it got the job done! On a side note my Duramax would get about 11 on this exact same trip but did it without breaking much of a sweat it it cruised all day at 70-75.
In the end I'm extremely happy with what this little truck did. If I was going to be travelling any further than our favorite spots, I'd get a bigger truck (and after getting to know this truck it would probably be a Ram) because its just too stressful. Maybe if I can get the handling worked out I'd change my mind. Hopefully some of the experts in here can chime in and tell me what I may be overlooking without telling giving me the big trailer little truck line. I should be able to drive in a straight line on flat ground at 55mph...I think..LOL
I'll leave you with another photo of the setup. Thanks in advance for your input!
