CAMSHAFT LIFT ISSUES
ARTURO MACHADO
CD. OBREGON SONORA MEXICO
RAM CHARGER 1979, RAM 1981, RAM 1987
5.9 LA, 5.9 MAGNUM, 5.9 MAGNUM
I WILL INSTALL TO MY 5.9 MAGNUM A CAM WITH AROUND .550 OF LIFT. DO I NEED ADJUSTABLE ROCKER ARMS, OR WITH THE OEM ITS ENOUGH? IF NOT, WHAT ROCKER ARMS DO YOU RECOMMEND?
dudeman2009
2001 1500 Sport with enough electrical modifications to make my brain hurt
Magnum 360
Just a question. Does your caps lock work?
Aside from that, what year truck? do you have it tuned? is the intake and exhaust stock? Heads?
In the Magnums you have hydraulic lifters that will collapse some to make room for a little extra lift if you don't get the rockers perfect. Harland 1.7 roller rockers are pretty good, a lot of people use them. But any 1.7 roller rocker really will be just fine, and make it a little more 'snappy' as some guys put it. But stock will work.
dapepper9
Iowa/Nebraska Border
5.9L V8
You need adjustable. And you'll get ptv contact above about .540 on an otherwise stocl engine
