Can I fit 37x13.5x20 Kuhmo tires
lowone01
hemi
I am looking to see if I can fit a 37x13.5x20 Kuhmo tire. Truck is a 2013 1500.
Truck specs are:
6in Rough Country lift
Fox 2.5 Coil overs in front
Zone upper control arms
Fox 2.0 shocks in rear
Tuff truck Heavy duty coils in rear
Rims are 20x9 -12 offset and 4.5 BS
Thank You
Limitless
I just put these 37/12.5/20 toyo RT and 20x12 wheels on and it rubs pretty good with a 3.5" lift
L
lowone01
hemi
Looks good but that's a 2500 and I have a 1500. Also that looks like a lot of negative offset.
CLOUDL1GHT
Lone Star State
Cummins HO
you should be able to fit with very minimal trimming if any needs to be done at all. make sure to post some pics when it's done!
brandonjansen
Abbotsford, BC, Canada
2012 Ram 3500 Laramie Limited
Yes, if you have the Fox coilovers cranked up they should fit no problem. A small amount of trimming to the back of the inner fender liner would be the most you'd need to do.
