Can I please get a favor from someone with a bone stock 1500 4x4 Crew?
Matts175
With 20" wheels.
Can I have your ground to wheel well measurements at all 4 corners? What I'm trying to figure out is that some are saying that the Outdoorsman (which I have) is factory raised 1" from a non Outdoorsman. I have Googled this to death and there are conflicting reports. Why is this important to me? I want to install Bilsteins and I only want to do this once. Don't want to set them at 2.1 and really only get 1.1.
I'll post mine up soon. We are right in the middle of a crazy ice storm right now.
markwoodlief
Mount Vernon, WA
give me a minute.. I have a new left over 2018 1500 BigHorn Crew Short Bed 4x4, stock 20's. I'll go measure now.
markwoodlief
Mount Vernon, WA
Drivers Front: 92cm / 36.22 inches
Passenger Front: 93cm / 36.61 inches
Drivers / Passenger Rear: 101cm / 39.76 inches
Matts175
Matts175
Thank you very much. Still freezing rain out. My Mother just called me, she lost power. It's a real mess here right now and I have to go to work soon in this mess. So glad I decided to get a 4x4 this time.
ram1500rsm
Trabuco Canyon, CA
2014 Crew Cab 4x4 with stock 20" wheels and tires measured 36 1/8 front, 39 1/4 rear.
TigreST
Canada
Something/somewhere else to look. Follow the link below and type in your VIN (no dashes...just letters and numbers...letters need to be capitals I think) and you will see the "broadcast sheet" / build sheet info for your truck (I hope). I did this with my 2018 RAM 5.7 Crew Cab/Sport and I read:
"Raised Ride Height"
"Spring-Right Rear"
"Spring-Left Rear"
"Spring-Right Front"
"Spring-Left Front"
Maybe yours will give similar info which may at least indicate that the ride height is factory altered. Here's the VIN decode link:
https://fcacommunity.force.com/RAM/s/equipment-listing
This works (as it states on the link page) for vehicle after 1998.
HTH,
T.
Matts175
Matts175
"Spring-Right Rear"
"Spring-Left Rear"
"Spring-Left Front"
HTH,
T.
It does say "raised ride height".
TigreST
Canada
BTW, living the same ice storm dream as you...just across the bridge from Port Huron MI. It's sucking big time!
swine
NE Indiana
FWIW, I also have a 2015 Outdoorsman and I set the Bils at 2.8" It perfectly leveled the truck (no rake), but only raised the front 1.75" from stock. And I'll just add that I'm running the stock UCA's with no issues (40K so far) and my shaft angle is fine.
Matts175
Matts175
Good info. Thanks!
Still can't get my measurements. We are just getting pounded with bad weather. Actually, just got in from plowing (with my Can Am 4 wheeler) ....again.
TigreST
Canada
Bit more info (photo) to share. Back in the summer...you remember summer doncha?...it's like today only that white stuff is gone. Anyway, I was trying to decide on a wheel and tire package. I had it narrowed to the Hellcat style replica's but was not sure on tire sizing. As I had a set of OEM SRT-10 22x 10 brushed alum.'s I did the change out and measured wheel well opening differences. Attached you will see my attempt to measure and record the stock OEM 20x9.5 Sport wheels and the stock Goodyear SA-R tires wheel well clearance on the front end. Sorry, no pic's of the rear end.
T.
Neumie
MN
5.7 8a
"Spring-Right Rear"
"Spring-Left Rear"
"Spring-Left Front"
HTH,
T.
My Bighorn said that.
Matts175
Matts175
Ok. Finally some 40 degree weather.
I guess the Outdoorsman is a smidge higher, but nothing significant.
36 and 3/4" driver's side.
37 exactly passenger's side (I wonder why it's higher?)
39 and 3/4" both rears.
So, it looks like Bilsteins set at 2.8 would put me just about level. If not, I'll throw a 1" in the rear. :)
