Can I upgrade 5’ to 8.4’ uconnect
Mohammed Albasir
Tripoli\LIBYA
5.7L
"I want to upgrade the radio in my 2016 Dodge Ram SLT from a 5-inch with 7speed to an 8.4-inch screen, which I took from a 2017 Dodge Ram Longhorn. My question is, can I use the harness from the Longhorn's 7-speed fan controller for AC or can I use the existing harness?
mikeru
Super Moderator
Moderator Supporting Member
2020 Limited
Hemi 5.7L non-Etorque
SitKneelBend
Moderator
Member Relations Specialist
St. Louis
3.6 Pentastar
You need a conversion harness and a new HVAC module at minimum. If you're looking to buy a harness to convert, forum member @Mpgrimm2 can sell you one and tell you exactly what you'll need to convert your truck.
Mpgrimm2
Supporting Vendor Navy Badge
SC
2022 Ram 1500 (5th Gen)
5.7L
Neither will work. @SitKneelBend is correct on what you will need at a minimum. What else you need will depend on your additional details about your truck and any additional parts your have.
M
Mohammed Albasir
Tripoli\LIBYA
5.7L
M
Mohammed Albasir
Tripoli\LIBYA
5.7L
Thank you for your response
I had dismantled the HVAC Module with harness from the donated vehicle, waiting to arrives then I’ll try to install it.
Will it work for me? Or I need more materials?
bradstephens25
