Can mds be disabled
Boudreaux
Welsh, LA
2016 ram 2500 4x4
Is there a programmer that allows the mds to be disabled available at this time?
Cruizer
Ohio
2010 Sport 4x4 QC
I'm not an expert, but I believe a lot of the tuners out there allow you to disable the MDS.
THETANK
up jor *** mang
2015 R/T
or just use the lower gears to avoid ie on the 8 speed go no higher than 6th as far as I know anyways.
B
Boudreaux
Welsh, LA
2016 ram 2500 4x4
Ok thanks. I figured as much. Just wanted to make sure
RyanJM
Houston
2014 Express RC Black Edition
The diablo tuners can.
Cruizer
Ohio
2010 Sport 4x4 QC
/nobodysearchesanymoreistheFAQdead
I'm fairly certain this is not the answer we give members here. I'm sure the idea at RF is to be helpful. Not everyone that finds their way on to this forum is a forum expert.
Canyonero02
2014 Ram 2500
Not sure about the 1500's but on my 6.4 if you use the gear selector select your gear it will turn MDS off. So say I select 6th gear it'll still use all the gears but will not use MDS.
Andy578
Ontario, Canada
2014 Outdoorsman
tow/haul should also disable it but i've heard conflicting reports and haven't tested yet myself
Cruizer
Ohio
2010 Sport 4x4 QC
I do run tow/haul in town. Keeps from getting stuck between 1st and 2nd when I turn on to streets. My Eco light never comes on in tow/haul, but I've heard that doesn't mean MDS is actually off.
Andy578
Ontario, Canada
2014 Outdoorsman
i get the eco light with tow/haul. i don't believe it has anything to do with MDS or at least MDS is only part of it, seems to be more about how much throttle you're using but i've yet to find anyone that actually knows what all goes into triggering the indicator
DisturbedGator
if you have an 8 spd. MDS will not shut off in tow/haul. if you want to run mds off just select gears and go all the way to 8. Thats how im running till my tuner gets here.
cgeorgemo
Joplin, MO
3.6 Pentastar
I get the ECO message all the time and I've got a V6 so it isn't just for MDS...
B
Boudreaux
Welsh, LA
2016 ram 2500 4x4
Thanks for the replies, I guess I could have been more specific. I am mainly asking in regards to the 6.4 in a 2500. Hoping to buy this fall as soon as I am done remodeling the home. It's even better if it can be bypassed without buying anything as has been suggested so thanks again.
B
Boudreaux
Welsh, LA
2016 ram 2500 4x4
No apologies necessary. I understand sarcasm well as I am quite fluent in it. Sometimes it's just easier to ask people who know about something specific than to search all the different companies out there.
Canyonero02
2014 Ram 2500
So in short, yes. Just select 6th instead of D. It uses all gears and shifts normal, just doesn't use MDS. That's how my 6.4 works.
