- Jan 5, 2011
- 13,086
- 28,503
- 2016
- hemi 5.7
Yeah Bedliner won’t work. Rust will just pop through
You have to fix the rust first.
Yes. I been that route. Had the rust “taken care of” and then Bedliner and then painted. Well the metal gets quite thin from being sanded down and it doesn’t take long for the bubbles to return, pop and rust come through.You have to fix the rust first.
Yeah that’s where I eventually ended up. It all started with me noticing 2 small little bubbles. I took it to a body shop the guy there had a look. He explained to me that eventually I would have to get it cut out and new piece welded back in. He told me that he could sand it down add Bedliner and paint to match. I was told it would last a couple years but eventually it would need to be cut out and new metal added.To do it right you have to cut the rusted sections out and replace them with new ones.
My 2008 started to get a little bubble action going on the left rear fender, I cut it out and welded in new sections and then re painted the whole bed side so that it would match up.
a year from now that truck will be rusted clear out.
Yes. But that doesn’t mean it’s not fixable and he has to sell it cuz “that truck will be rotted clear out”Lol, wait and see.
I have seen some like that before and with in a year it had holes in it.
Once it starts coming through its allready rusted really bad on the back side.
You can definitely address and correct rust issues. Now if it’s everywhere then different story.
Yeah i get that and I get that it’s a Canadian truck but Ohio gets its share of nasty winters too. Like I said if it’s a little rust then you address it and take proper measure to prevent more rusting and you can have that truck for many more years to come. I think anytime you live somewhere with harsh winters rust is always gonna be a concern.Never said its not fixable pretty much anything is to a point, but I bought a new truck because I dont want rust and if it was mine I would dump it.
My 07 had bubbles forming above the rear tires and was starting to break through and I did not want to dump money in it so that was one reason I got rid of it.
You do rockers and cab corners arer the bed sides next ? What about the front fenders thats what would scare me about keeping it.
Just saying for me I would sell it, even at a loss.
I always thought Ohio was in the so called "Rust Belt"?
I hear ya, sounds like the highways we have in southern Ontario“Salt belt”, “rust belt”, same thing, it’s terrible up here in northern Ohio. Our roads are white long after the snows gone...
I Bleed Ram Trucks
That sounds like a great (too good to be true?) quote to me!I have a written estimate to replace the rockers and back cab corners at $1800.
