Canbus hid kit
Steveo8x8
So Cal
2017 Ram 2500 Megacab
6.7l Cummins
Anybody have any luck installing a canbus hid kit and hiding the ballast and adapters inside of the projector headlight. I prefer a clean install and don’t want to see wires. On my 2013 with quads I was able to hide everything Inside with no issues
U1arunit
Aliquippa, PA
Not sure about all kits out there but my GTR lighting one from Headlight Revolution would not fit inside on my '18 Sport with projectors. I have both low and highs installed but even one would not fit in the housing.
Ram Night
Southwest, Michigan
I have the 35 watt hid low beam kit in the projector that I purchased from The Retrofit Source. You will have to mount the ballasts and igniters outside of the housing. The kit comes with a waterproof boot that has the wires in it that works great.
Check put the difference between stock low beam with fogs and HID low beam with led fogs.Stock Lights.jpg +HID low and XML2 Led fog.jpg
Jrod
USAF 1997-2008
Virginia
2025 Laramie
SST SO
Very nice! Which kit do you have?
This was someone else who stuffed everything in their projector. I did not. We both have DDM tuning HID canbus 35W 5500K. Some people have had issues adjusting their headlights after cramming everything in there. I opted to drill the hole in my dust cover, and screw the balasts to the frame underneath the headlight with metal tap screws. I've had zero issues. DDM is plug and play. No grounding and No having to run a power line to the battery.
Steveo8x8
Steveo8x8
So Cal
6.7l Cummins
Ok great. I adjusted mine a year ago and have been happy with where there at at with my halogen bulbs. Hopefully I won’t have to adjust them again
