Cat oil filters
Stumbled across this on 1 of the car pages.Fits the 5.7 and 6.4 cars,not sure about the trucks though.
Curious on your guys thoughts on this Cat filter.
HEMIMANN
Minneapolis, MN
2017 2500 Laramie Crew Cab
6.4L HEMI
Apparently, a new-ish joint venture corporation is making filters for CAT. Looks like a private-labeled Donaldson filter, made in Illinois.
Found this link over @ Bob's, site looks like a number of types of filters. I saw fuel & oil, not sure about coolant and air.
No doubt the quality is there, but likely keep their filtration efficiency curves a trade secret.
MrBonez
Central Alabama
2008 Laramie Quad Cab
If it fits it should be fine, I've never really known Cat to have bad filters in their branded stuff.
Only problem I can think of is will it fit....
You can't install a really tall filter (At least on mine - 2008 truck with a 5.7) due to possible interference with part of the metal structure (Frame) directly beneath it.
A fat/larger diameter filter would probrably be fine as long as the oil filter's O-Ring pad it has is the correct size but a taller one might have issues, depending on how tall it is.
Also, you really don't want a honkin "Fat" filter either since it's kinda close to the block once installed.
