Catback for RT
bgray
Canada
Corsa Catback for RT
Hello all.
I have been collecting parts waiting for the arrival of my 2015 RT. I got a Corsa Catback for it, and just noticed it says its for Crew and Quad cabs. Corsa said its not a direct bolt on, and thinks the pipe comming INTO the muffler will need to be shortened.
So I started to peak around for what others are doing, mostly magnaflow findings, and that seems to be the case? Can anyone confirm this.
If i had the truck it wouldnt be an issue, but Im still a few days away and trying to get my ducks in row
Brandon
bgray
bgray
Canada
Buddy
Ottawa, Ontario - cool town
Worst case is you have to take it to a shop and mod it to fit. Corsa is probably one of the best exhaust companies out there. :favorites13:
bgray
bgray
Canada
Agreed. I have them exhaust on my 2 other GMC Sierras, and modded a WRX kit to fit my Wifes Legacy spec b. Absolutely hands down the best.
Just curious to what will need modding
Tyrant
'12CC / '15RCSB
I think the Corsa's will fit without issue.
i installed the magnaflow 16869 on my reg cab SLT and all i had to do is buy he rear driver side hanger as my truck was a single exhaust. (the magnaflow part number is the same for all cab lengths except for the crew with 6' 4" bed)
the center muffler on the rams is the same for all trims (5.7l) my 2012 crew cab is the same as my 2015 reg cab.
the only difference is the pipe length from the cats to the muffler, the Corsa / Magnaflow etc.. center mufflers are designed to mimic the OEM original length so you wouldn't have to cut anything.
bgray
bgray
Canada
Thanks for the incite, just what i was looking for. 1 more day and i'll be able to give a 100% answer for anyone searching down the road for this
bgray
bgray
Canada
Answers
Fits Regular cabs fine. Had to trim about .5" off the end of the tailpipes to get the tips to tuck in better. Also the Passenger side was about 3" lower...So I have to bend the 1 portion of the hanger out of the way, and reposition the isolator. Fits great now tho.
Very little work needed.
Heres a video. In typical Corsa Fashion, Zero drone and IMO sounds amazing.
[yt]npFuaJfnCJ0[/yt]
https://www.youtube.com/watch?v=npFuaJfnCJ0
