Catch Can Hookup
Toolman
Middle TN
Did I hook this up correctly, or does it matter? I didn't think twice about it when I installed it, but I've watched videos and looked at other installs and I've seen it hooked up this way and with the hose connections swapped. I've only had it on for a couple days and it's already starting to collect oil, so I know it's working, just don't know if it's hooked up backwards..
tantore
texas
it looks good i went and and look at mine same set up
Tyler Yates
Iowa
I think either way will work. Ive seen several of either way
Simpleman
New jersey
I hooked mine up the opposite way but it really doesn't matter. Ive had mine on for about 3 weeks and just checked it and there was some crap in there so they do really work
madtrucker2016
New York-Staten Island
3.0 Hurricane twin Turbo
their is a inlet and a outlet on these cans. because the good ones come with a baffle in them so you dont get blow back.
Cableman
Longisland
I called upr Joe when i did mine and the hoses get crossed. There's a little steel wool filter on one side but i cant remember which!
My Moroso catch can's have a steel wool separator on both sides,so they don't care which way they are hooked up.
Toolman
Toolman
Middle TN
Well I hope it's not an issue, I couldn't remove the hoses from the barbs on the can.
If it's directional, then the filter should be able to be swapped to allow it to be hooked up either way.
Toolman
Toolman
Middle TN
If they did, I missed em.
I thought I'd re-check the instructions, but the download link on the UPR website just gives an error.
Lyle Longboat
2011 Ram 1500 5.7 Sport CC
Moosonee, ON, CANADA
Depends where you buy, some are either way (moes/UPR), others (Amazon/ebay)have your inlet crossed to the front and outlet to the back. Just open your can and look for the baffle, which side it is, that’s your inlet side. Again, some don’t matter.
madtrucker2016
All the catch cans are not made alike ,so like mine has a baffle chamber ,it,s marked only on the paper work>> in and out. But from everything I have been reading we all should have one on our engines. Gives the engine more life protecting it.
