Disclaimer: Links on this page pointing
to Amazon, eBay and other sites may include affiliate code. If you click them and
make a purchase, we may earn a small commission.
Other side isn't bad. It's got about 195,000 miles. Yes, that many. Just got done changing oil, cam position sensor and the oil control valve that is under the intake manifold. The two parts were from a p000b code that came up in the last couple days.
Will do. Ithe would help if I could keep my wife off the throttle.
I was starting to think I might have an issue with a piston ring or two. I might do a compression test anyway to rule it out. If that's the case I might just cry and fork out money I don't want to.
