retiredfireman
Ok, so, I decided it's time to change the diff fluid on the Ram.
Got me 2 Qts of Amsoil 75w90 and 1 4oz. tube of limited slip additive.
In the past, I have removed the diff cover, but I see that we have a drain plug and fill plug, so I decide to use them.
First off, I find it is NOT a square insert, like the old ones, but a 6 point 9/16 hex insert.
Of course I don't have one of these the right size:
so I need to improvise.
I first thought I could use a bolt with two nuts jammed together on it- no go.
then I decided to use the same bolt and file down/crush in the vise to get an open wrench on it - vise afterwards:
so then I went to the hardware store and got one bolt and 4 nuts, and jammed them on as best as I could- end result- it worked:
