Check Engine Light and Fuel Guage
xXsummiesXx
Ive got a 2003 1500 SLT 4x4 and every time its above half a tank the CEL comes on, the fuel light comes on, and the fuel gauge goes to E. It usually doesn't happen until i get about 30 miles into to tank after i fill it up. Once it gets below half a tank the CEL goes off and everything works just fine. Anybody have an idea what is wrong.
MoparWild
GA
it sounds like the fuel level sending unit is the issue. if there is a break in the circuit board it may cause a cel to come on. it is mounted on the side of the fuel pump assembly and ease to replace if you lift the bed on the drivers side of the truck.
