check out my video and give me your thoughts
quietpeen
2021 TRX
Hellcat
first thing i would do is thake that tail light out and check the circuit board. They are known to go bad.
txbass06
NE Texas
5.9 Magnum
^^ This. We went through 3 new ones before we got one that would work on my buddy's '04.
Sent from my iPhone 4 using Tapatalk
02blkram47
02blkram47
Lebanon, NH
2018 Ram 1500 Limited
I don't have the original lights. I bought this with some clear aftermarket ones that don't use the circuit boards. So there is simply a pigtail that plugs into the original harness. once i get the video fixed you will see that they work very strange.
02blkram47
02blkram47
Lebanon, NH
Basically the lights work fine until I turn the driving lights/head lights on.then the tail lights on the right side go out but the directional still works.you will be able to see this in action as soon as I fix the video link
02blkram47
02blkram47
Lebanon, NH
Okay, I think I have fixed the link if anyone wants to check out the video and give me some ideas as to how to fix this. the link is in the first post above.
02blkram47
02blkram47
Lebanon, NH
Is my link working? Anyone check out the video?
quietpeen
2021 TRX
Hellcat
my next question is did this start right after you installed the lights or did you have them for a while?
02blkram47
02blkram47
Lebanon, NH
Those lights were on the truck when I bought it. I'm embarrassed to say that I don't know if it's been like this from day one because the truck was already inspected when I bought it so ask I did was register it.I did not get it re-inspected.
After thinking about this I just realized that my warning light just started coming on so this issue is fairly new.
quietpeen
2021 TRX
Hellcat
i'm thinking that it might be the actual aftermarket light
02blkram47
02blkram47
Lebanon, NH
any reason I can't take the light from the drivers side and plug it into the passenger side just to see if it works properly over there. if it does then I guess that will tell me it's the light and not the wiring of the truck.
quietpeen
2021 TRX
Hellcat
i can't think of any reason you can't. Just be careful with letting it hang loosely by the wires. The male end of the clips that hold it in can scratch the paint easily.
txbass06
NE Texas
5.9 Magnum
If there's enough slack in the wire, just set it on the tailgate lol
02blkram47
02blkram47
Lebanon, NH
I've had it out before and it will sit on the tailgate. I'll try that tomorrow and hope for the best.
02blkram47
02blkram47
Lebanon, NH
update on my light issue. I took both lights off and swapped them around. still had the same issue with that light when I swapped it so it appears to me my issue is with the wiring of that one light not with the truck. So I"ll buy some new lights and see if that corrects the problem.
txbass06
NE Texas
5.9 Magnum
Glad you got it figure out and it was just something with the lights and not the truck itself
