Check your intake manifold bolts
Sherman Bird
Houston, Texas
This hasn't been talked about for awhile,but check your intake manifold bolts.They call for 108 in-lbs or roughly 9 ft-lbs of torque,and they should be checked at least yearly,as they do loosen up. I've been doing mine at least twice a year on all 3 of of my hemi equipped vehicles.They should be checked and torqued when the engine is cold.I just use my calibrated hand and a 1/4" drive rachet / 6" extension and 5/16's socket and just give them a twist by hand,but if you don't trust your hand,an inch lb torque wrench should be used.There's 10 of them on 5.7's and 6.4's. I've done them enough,i know the torque sequence ,but if you don't know the sequence it's easy enough to look up
GM, having the same plastic intake manifold design, and the bolts pressing against sleeves to prevent damage to the plastic if and when a hamfist overtightens the bolts, uses blue thread locker on new bolts. When I remove an intake of this design, I reuse the bolts with said thread locker. I'd extrapolate that applying thread locker would alleviate the need to retorque... that is unless one just needs an excuse to be busy under the hood! ;)
W
Give it a whirl on a Hemi and report back to us in a few months what you find.
crackerjack1957
2014 Sport 1500 CC 4x4
Hemi 5.7...65RFE...4.56
W
Anyone using these?
If seal compression is the issue of loose screws.
Those look interesting CJ. Somebody needs to try them. I have a couple sets of the Felpro's on hand and not really planning on pulling any of my intakes for awhile,but those do look intriguing.
W
I'll let you do it! :)
Probably not,as i don't think it'll actually do much,as the heads run hot enough to keep blue loctite soft.That's your department to experiment on ;)
HEMIMANN
Minneapolis, MN
2017 2500 Laramie Crew Cab
Only way to see if screws are turning is to mark head of screw & matching mark on intake.
Right, but how could it turn if it is loctited in? Loctite was designed specifially to prevent bolt backing out due to vibration.
Something screwy (pun intended) is going on, here. O-ring seals can be compressed to solid surface, after which there is not more compression.
crackerjack1957
Could be wrong but 105 inch pounds not going to do much compression & I'm not sure if polymer intake makes contact with heads..........heat cycles & different materials will compress.
If I had an intake I would check seal depth with depth mics & compare to seal.
Or better yet place seal in groove & check with straight edge & feeler gauge.
Thread locker or not mark tells the story.
Sherman Bird
Houston, Texas
Locktite is a registered trademark, and I do not use that particular brand. I use the Permatex clone because heat DOES'T soften it! There! Experiment done!
W
That's assuming the bolts are backing off,but if it's because the manifold or gaskets are changing shape,a thread locker is going to make it tougher to stay on top of re-torquing them. A thread locker will be very deceptive at letting you quickly check them with just a nutdriver to see if they are loose.
So your experiment might not nessecarily be done,lol
crackerjack1957
So I guessing you use the high temp thread locker because the blue Permatex is less heat resistant than the blue Loctite
Interesting....high temp......medium strength
HEMIMANN
Minneapolis, MN
Sorry, I should have added I used it on pipe plugs on engines! Oil drains, hydraulic systems, etc.! Yes, there are still many applications that have pipe plugs instead of the more expensive o-ring face seal plugs.
I've not heard of Vibra Tight Brand. Where is this available?
crackerjack1957
New to me also, scroll down to bottom of the page on the link, it has a rolling banner with it's distributors.
I recognized a few like MSC, Grainger & Fastenal in my area.
04fxdwgi
Coastal NE North Carolina
2016 1500 Sport
Cool. It's on Amazon for $7 in red.
Yeah, it's called "torque striping". Added after torquing so QC inspector can, at a glance, verify torque is completed during assy. Good for tamper detection and general condition, over time.
Been doing it on BIG power components like xformers, generators, switchgear and UPS' for at least 20 years.
hdog33
Land Of 10,000 Taxes
Just a thank you to Wild One for starting this thread. My 2019 Laramie Longhorn bolts were around 25 inch lbs. I used my 1/4" torque wrench to tighten down.
And thanks to all who contribute to this forum! I've owned nothing but Ram trucks going back to '99 and while they all have quirks they all treated me right.
