CheechDogg's 2018 Ram 1500 Big Horn 2wd Build Thread
BTD07
2017 Laramie
Man ... look at it this way ... you only say promise one time and that is at the wedding ... she's going to say "promise" TWO TIMES ! at the wedding and with the promise of the lift KIT !!!!! YOU FAWKEN SCORED !
lol!!!
C
Riverside California
2018 2wd
HEMI 5.7 Revolution 4.88s
There is really only about 2" of gap but in the pictures it looks like more ... I will take another one tomorrow or this weekend showing how close it really is ....
Graygoose
Indecisive Car Owner
Oklahoma
Convert, for now.
small
Mine barely fits in my garage, I mean less than 1"....no ay a 7" lift and 37's Id fit in my garage.
C
2018 2wd
Well I finally got my RBP Stealth Power Running Boards installed on my truck and here is a little bit of how that went ....
I refused to cut anything, took me about 6 hours of tightening and loosening and bouncing and finally the fell in to place.
I’d be curious to hear from members who installed RBP to see their experience.
Well I finally got mine and installed them myself on Saturday morning....
It was a bit of a struggle getting the bolts in the inside of the front mounting points and that was with the threaded inserts...
The alignment after the two front motors were in place and the back ones were also on everything alignment perfectly...
It could of been easier getting those 2 flange bolts if there was more room to get your hands behind the motors and i have small hands lol...
I ran into a second problem when testing if everything was wired correctly and moving like it should... the passenger side worked correctly when opening and closing the doors... but the driver's side didn't....
The steps would not retract after closing any of the driver's side doors... i checked every wire and nothing seemed out of place... crimped or broken....
I then decided to look at the position of the sensors and magnets... compared them to the passenger's side and noticed that the driver's door was not aligned correctly... i took the magnet off and left it over the sensor and the steps retracted...
So the magnet was a bit off which made the system think the door was still open...
I had fun installing the RBP Stealth Power Boards myself... it took me a little over 4 hours because of the door and sensor issues but everything else was easy... very easy..
Here are some pictures of them
C
2018 2wd
So I finally removed the B pillar vinyl wrap and the ram 1500 badges...
Only one i didn't remove was the HEMI badge... what do you guys think.. remove it or leave it?
tnmotown
California
Man your truck looks awesome! I have the same color and also 2wd. I’m thinking about a 4” lift from RC with 35” tires but you are making me second guess lol. I’ll definitely be following your thread
C
2018 2wd
Go with the Maxtrac 7" with 37s ... you wont regret it ...yes you have to do some trimming but it is nothing major ...
C
2018 2wd
So I am going to be tinting my tail lights and head lights so I figured I would need better lighting ... I didn't want to use any anti flicker modules or expensive overpriced name brand LEDs so I Just ordered my Security Module Bypass and OBDLink MX+ which is getting here tomorrow !
The Security Module Bypass should be here in a few days !
Oh yeah! Now I can really do some fun stuff to mah' truck !!!! thank you @DeereGuy !
I will keep you guys posted and update you guys with the new changes I will be making with these gizmos !
Graygoose
Oklahoma
Convert, for now.
small
He had three levels, I chose the middle, so probably smoked.
$100 for both, OTD
C
2018 2wd
I'm just waiting for the VVIVID tint from amazon to get here and I will get it done ...I am going with the dark black on the back then once I get my led low, high and fogs I will decide of what to go with for the head lights ... Also waiting on my security harness, I already go my OBD link ... ooooh yeah !
Graygoose
Oklahoma
Convert, for now.
small
I used the Heise LED, fogs and lows...with the decoder, plug and play.
Graygoose
Oklahoma
Convert, for now.
small
I had a local dealer, maybe go see Pacific Stereo in Riverside, or find an Advanced car Stereo, ask for Heise.
Veldhuisen90
