CHMSL Cargo Camera install in a Classic
DoughRat19
Massachusetts
2019 Classic
Just wanted to give a heads up for anyone with a ‘19+ Classic looking to install a HD CHMSL with the cargo camera. After some testing, I have confirmed that certain software versions on the UAS/UAQ radios actually move the camera inputs on the back of the radio.
The normal cargo camera inputs are position 24, 25, and 26 on the main C1 radio connector. However, if your UAS/UAQ is in software version 28.3 or above, the inputs are moved to positions 21, 22, and 23.
This is specific to the classic rams only. The newer software versions are reading the vehicle year off of the BCM and since anything with a cargo camera is supposed to be a 2500+ (was never an option for a 1500), the software moves the input positions to the 5th gen input locations (because if it’s a 2019+ with a cargo camera it must be a 5th gen). I’ve confirmed the software is looking at the vehicle year because when I change the year to 2018, the 4th gen input locations work again.
Mpgrimm2
Supporting Vendor Navy Badge
SC
2022 Ram 1500 (5th Gen)
5.7L
Glad you were able to confirm this.... Another stellar example from Mopar engineers of changing/moving things around for absolutely no dang reason.
(Like they did in the 13-15 Rax 8.4 Harmon radios b/w v17.11.x and 17.43.x)
BucketGruntJL
OKC
Good info Matt! Regarding the cargo camera maybe you can answer....I have access to a CHMSL with cargo cam from a 2021 2500 with surround view. Would I be able to install this into my 2015 2500 Laramie with a 2018 UAS? I vaguely remember reading somewhere about surround view systems having a different signal processing but don't recall entirely.
DoughRat19
DoughRat19
Massachusetts
2019 Classic
Sorry, just seeing this. The camera will not work in a 4th gen, it is a digital coaxial camera where as the 4th gens are a 6 pin analog camera.
