CHMSL W/Cargo Camera OEM - Install Help
67Stang
Indiana
My Truck 2017 1500 Big Horn
I installed a used CHMSL with camera from a 2500 Ram. I have had the lights working for some time now but I just got around to wiring up with harness I made based off the information I could gather. I followed MKS Performance & Offroad video on YouTube knowing his was a 2500. I put together a spreadsheet to help me keep everything straight. 1660562739314.png
Everything has gown as planned until I tried to find Lin Bus CBC3, and Run Relay Control at i440 behind the drives C-pillar. They don't seem to be wired in on the 1500, or at least mine. I have everything complete I just need to find where to connect to these two wires. If you know where to find these on the 1500 please let me know. If you have a wiring diagram for my truck that would also be helpful. Thanks,
This might be the 3rd brake light that has 2 cameras
1 is a Cargo Cam, the other is a video camera
but it should show you how to run the wiring
it covers the CBC3
67Stang
Indiana
Thank you, that is the YouTube video I used to make the spreadsheet. It is also what it followed on my install. The video was very informative but the issue is on my 1500 the two wires are not at the plug behind the C pillar. I have already landed the two wires on the tops side of the plug just as shown in the video as I prewired my harness. But CBC3 and Run Relay are not their.
If anyone has a wiring diagram from my truck that would be very helpful. I thought I remember several members did this install on their 1500s. Any insight from someone who has completed this install would be great. I am so close to having this project finished up.
67Stang
Indiana
I sent @Mpgrimm2 a private message the other day, still wating to hear back. I will try @DeereGuy as well. I already made a harness and have alot invested in parts and time i just need a little more help to get it finahed up. Thank you for the info.
Rav3ncroft
Indiana
2018 RCSB Sport
Hopefully one of them can offer guidance.
SitKneelBend
Moderator
Member Relations Specialist
St. Louis
3.6 Pentastar
This site can get you the pinout you need.
Mpgrimm2
Supporting Vendor Navy Badge
SC
2022 Ram 1500 (5th Gen)
5.7L
18ram2500 reference ...
  • 2018 Ram 2500 BACK-UP-CAMERA-SYSTEM---EXCEPT-CHASSIS-CAB.pdf
Mpgrimm2
SC
5.7L
17ram1500...
  • BACK-UP-CAMERA-SYSTEM.pdf
67Stang
Indiana
Thank you for the diagram. I have some new pins on order to connect it to the original intended location. It's odd looking at the 2013 diagram of i440 it shows they should be thier on all trims. They mist have dropped them at some point. I was not able to find the i440 diagram for the 2017 1500 to confirm.
