Clayton lower control arms on. Pics.
VelocityC6Z
Maryland
Yep both. I’m running the full set.
Awesome, thanks!
Is the panhard/track bar on there site that's listed for the 2020 Gladiator also fit our trucks? I'm thinking it will? But want to make sure. Ours is flimsy.
Cheers!
Ram7081
Ram7081
HEMI 5.7
Awesome, thanks!
Cheers!
What does the panhard/track bar do? Does it help if you are lifted?
Ram7081
Ram7081
HEMI 5.7
Yep it shout fit, COR-4510110
On the lca I matched oem to new Claytons (as shown in pic on original post). On the track bar, I assume you don't do it this way since my rear is lifted? Do I adjust to fit per say?
crazykid1994
If you have a lift kit that reuses the stock bar you should be fine set to stock length. Only reason otherwise would be using parts to lift that don’t readjust the stock track bar
Ram7081
Ram7081
HEMI 5.7
I have the lifted coils and spacer. I am guessing 1.5" lift in the rear.
VelocityC6Z
Maryland
Ordered my control arms and track bar today. Nice find on the DDB's used here. You guys are great here. Nice to know the gladiator stuff fits. Claytons has a great name on the Jeep world, I'll trust them any day on my truck. Can't wait for them to show up.
VelocityC6Z
Maryland
JJ's were incredible for the last 15 years, but the DDB's just have a lot of great reviews that I'm seeing. I'm surprised at the cost... and claytons reputation is great. Pretty happy with this.
Mopar1987
Livingston TX
These things are BEEFY!! My goodness. 1 lower weighs more than all 4 factory arms. Still can’t do a standing burnout without wheel hop, but I didn’t build the truck to do that anyway.
Mopar1987
Livingston TX
And they definitely feel more planted on the road. Just feels solid in the back.
VelocityC6Z
Maryland
Nice! Can't wait for mine to show up.
I just added the core sway bar end links in the rear and that made a noticeable difference in stability. I would recommend those as well.
crazykid1994
My Core4x4 rear links are supposed to show up tomorrow. wooo Woooo :)
I love mine. Only issue I had was the grease fitting would have hit the bracket so I mounted it to the outside of the bracket instead of inside like stock. Also pulled them apart to grease them better before install and used red moly grease Which is better for poly bushings.
tigger54
