Razzaa
- Aug 10, 2013
- 860
- 185
- 2013
- Hemi 5.7
Powertrain - Auxiliary Emission Controls - ISO/SAE Controlled
Description
EVAP Purge Flow Monitor Fault Conditions
Cause
Engine running in closed loop, ECT sensor over 170°F, engine at idle speed for 2 minutes, Low Fuel not on, MAP sensor input under 15 7" Hg, altitude less than 8000 ft , PTO not enabled, then the PCM detected that no airflow was present through the EVAP system in the test period Refer to Monitor Test, code repair chart to test the code Note: The stricter EVAP purge flow test is used to verify the EVAP system functionality on vehicles with the LDP
I just pulled this code off my truck. No CEL on though. Can someone please give me an explanation as if I were a child lol Thanks.
Description
Cause
