Code P0441?
Razzaa
Powertrain - Auxiliary Emission Controls - ISO/SAE Controlled
Description
EVAP Purge Flow Monitor Fault Conditions
Cause
Engine running in closed loop, ECT sensor over 170°F, engine at idle speed for 2 minutes, Low Fuel not on, MAP sensor input under 15 7" Hg, altitude less than 8000 ft , PTO not enabled, then the PCM detected that no airflow was present through the EVAP system in the test period Refer to Monitor Test, code repair chart to test the code Note: The stricter EVAP purge flow test is used to verify the EVAP system functionality on vehicles with the LDP
I just pulled this code off my truck. No CEL on though. Can someone please give me an explanation as if I were a child lol Thanks.
Arctic-Rodz
RGV, TX
6.7L Cummins
Mine came up with that code a few months ago. Read it on my T1000. I tightened the gas cap and cleared it on the tuner and i haven't seen it anymore
Lurchav8r
