Codes P20E9 and P208D
jdw8251
South Carolina
2016 2500 Cummins popped both codes a couple days ago. P208D code had 3 occurrences and I was able to clear those, but the P20E9 code was a permanent code. I know both are related to the DEF pump. Truck has 140,000 miles on it so fully expecting that the pump is bad. My question is, has anyone had any luck with the $400-500 aftermarket pumps vs the $1680 OEM pump? If so, which aftermarket one did you buy? Thanks, JD
