Coil Spring airbag inserts compatible with existing spacers?
Marty1500PNW
Puyallup Wa
5.8 l V8 HEMI
Pretty much like the title says. I have a 2017 1500 with a leveling kit, 1/2" spacer on the rear. I'm wanting to install Airlift HD 1000 bag inserts in the existing springs. I can't find any info about if they will work with my current setup. I'd like to avoid removing the rear spacer as it sits dead level right now. Anyone have any experience with them? Thanks!
John Jensen
San Diego County
Ecodiesel
I wouldn't think a spacer would have any effect as those bags just slip into the spring.
If you do get the 1000s be sure to inflate them before you add your load. If you inflate after you add your load, they will merely squish out between the coils and would be ineffective.
DILLIGAF
Canadian Forces
Canada
Get timbrens, Almost the same price and no stupid bag inside the springs.
noraa73
