Cold air intake
Shoe0402
Pa
Hi guys I got an Amazon gift card from work and was looking at getting a k&n cold air intake for my 2019 new body style ram. They have two different kinds one is more of an open box which is the 77 series i believe and the other is more of a closed box style. I want one to have a bit more tone in it. The 77 series is a little more and I was thinking maybe the open style which that is would sound a bit better? Let me know if you guys know. Also do the throttle body spacers do anything?
misfit77
Looks like the box one will be closed when the hood is closed. U probably wont hear much.
If money isnt an issue, i would go box. The other will be louder but its just a hot air intake.
Sent from my moto g power using Tapatalk
S
Shoe0402
Pa
Musky Mike
NC
Your 2019 from the factory has a cold air intake, that draws air from the front of the truck...I would only choice one that uses the factory opening or your are going backward.
rule18
Admin
NY
2017 Rebel
The boxed one is actually cheaper. Here are the links to both of them.
K&N Cold Air Intake Kit: High Performance, Guaranteed to Increase Horsepower: 2019 Dodge Ram 1500, 5.7L V8,63-1578 https://www.amazon.com/dp/B07PRJRQ3M/ref=cm_sw_r_cp_api_glc_fabc_-BK2FbNYCVYRG
K&N Cold Air Intake Kit: High Performance, Guaranteed to Increase Horsepower: 2019-2020 RAM/DODGE (1500) 77-1578KP https://www.amazon.com/dp/B07NLJVQSN/ref=cm_sw_r_cp_api_glc_fabc_xCK2FbFPDBG90
Welcome to RamForum. For future reference, our Preferred Vendors can hook you up. https://www.ramforum.com/categories/preferred-vendors.80/
Musky Mike
NC
Both are a waste of money and you loose efficiency, if you're not using the factory cold air duct at the front of the truck, you're just wasting money. Look at this link to see what I mean about the factory cold air duct.
https://www.ramforum.com/threads/how-to-install-corsa-air-intake.169049/
HEMIMANN
Minneapolis, MN
2017 2500 Laramie Crew Cab
6.4L HEMI
I would suggest you look at S&B Filters CAI. After much research, I found their design to be least restrictive. I've had mileage improvement after install.
Throttle spacers do nothing - this isn't the old carbureted days with risers to increase airflow velocity. Use a venturi throttle body instead - I used Moe's. Much snappier pickup from idle.
S
Shoe0402
Pa
Do you hve a link for the throttle body you use?
S
Shoe0402
Pa
Also with the s&b filters do you just add a cone filter to your current system?
Daw14
South Florida
Do not just buy K&N cause all the cool guys have them. There are much better options available,stay away from oiling filters, that went out with oil bath air cleaners!
S
Shoe0402
Pa
Or does anyone have a reasonable price catback system? Or something to buy for the truck
rule18
Admin
NY
2017 Rebel
If you're looking outside of Amazon, check out the link in my previous reply to you, our Preferred Vendors can hook you up.
S
Shoe0402
Pa
What would be a better choice?
Daw14
South Florida
Volant with Donaldson PowerCore filter, s&b ,one that does not require oiling.
NDanecker
Earth
On a stock truck without tuning - just a waste of money. No different than buying chrome for the truck to make it look faster. LOL
