Compresion test procedure?
jessyj
abbotsford, bc
So I have all 8 plugs out and figure I will do a comp test, can it be done with all the plugs out? Thanks for all advice.
smithwessn
Yes. Disable the fuel pump and your spark source first.
dapepper9
Iowa/Nebraska Border
5.9L V8
Unplug the injectors and remove plugs then hold the pedal to the floor while you crank it
Yeret
Professional Procrastinator
Behind a computer saying, "looks easy enough..."
5.9 Magnum
^ When I tested compression in my engine years back, I pulled the fuel pump relay in the PDC and unplugged the ignition coil. Bit less trouble than unplugging several things, yes? Or is there a reason not to do it this way?
