Connecting to the turn signals.
whteglve
Winston-Salem
HEMI 5.7
I about to add a set of ditch lights to my 2018 Laramie 1500. The lights in planning on using have an amber section that can be light separately. It's like to wire the main light to a switch but have the amber work as a turn signal. Should I just run a relay for each part of the light? Do you think the control wire for the relay will cause issues with the computer thinking builds are out?
SitKneelBend
St. Louis
3.6 Pentastar
1. Yes, run a relay
2. If you want them to run independently you will need separate relays and triggers. It sounds like you will need three if I understand this correctly (one relay/trigger for left turn and another for right turn as well as one relay to energize both ditch lights simultaneously).
3. No, should be fine if you are using relays.
mtnrider
Georgia
I would also add a flyback diode across the relay coil to prevent any back EMF. I do that as a general practice when piggy backing anything on these trucks since all these functions are controlled through the BCM.
