Coolant leak/coolant temp?
Gottobecdn
2010 SLT
Woke up to a puddle on the driveway this morning. After a lengthy inspection I still can't fing the leak. Majority of lost coolant is on the frame rail directly below the crank, leading me to believe the water pump but nowhere around the housing nor the hole behind the pulley is wet. A wiring harness is soaked directly below the thermostat housing/temp sensor also.... All hose connections are good, definitely coming from the engine side and not the rad... Any ideas? Coolant temp is running around 204 (0utside air temp is 68 today) did peak at 206 at one point..... Anyone know what the preferred coolant temp is? One theory I have is high temp resulted in coolant blowing past o ring on temp sensor but honestly I don't really know what's going on.
2010 SLT, 5.7 Hemi
09hemicrew
MN
Cummins 6.7
Did you ever find your leak? I'm having a similar leak on mine. Thanks!
HolyRamBatman
Deep in the Heart of Texas
If you can't see where it is coming from, dry everything as best you can.
Start it up and look for it to start dripping.
Follow that as far as you can(with the engine OFF).
A flashlight is handy.
G
Gottobecdn
2010 SLT
I did find the leak after months of head aches.... Water pump gasket was the culprit. it failed in the top right section. decided to replace the whole pump and gasket, i drained/ flushed and replaced the coolant. all is well and my driveway is now happy
