Coolant leak
Jim Thornhill
Fate, TX
6.7l V6 Cummings
Hello all,
I have a 2015 new to me Ram 2500 w/ 6.7L Cummins that has recently developed a coolant leak. I can't actually see the leak, but it seems to be coming from the passenger side below the alternator. I have removed the plastic skirt from under the fender on the same side and have a clear view of the lower radiator hose and another unidentified hose about the same size. I can see that they are wet but I don't actually see a leak, especially seeing how fast the coolant is running out from under the truck. From the ground, everything is wet, more so on the passenger side but again, I cannot actually see anything leaking. Does anyone know where I can find a diagram of what coolant hoses are on the 6.7L engine or know if there is a coolant hose hidden in below the alternator that I cannot see?
