Coolant leak
benny68
South carolina
2013 5.7 hemi with new lifters, head gaskets. Leaking coolant from passenger side and running hot. I put 2 gallons of coolant back in it. Driver side seems fine. Any idea?
Jeepwalker
WI
2012 Reg Cab, 4x4
Did you check the underside of the water pump...looking 'up' from the bottom with a flashlight. There's a weephole on the bottomside. That's there to allow coolant to escape when the water pump seal goes. Look for potential leaky hoses too when you're under there.
Otherwise, check the heater hoses (and fittings) which lead to the heater core back to the firewall. Those the a couple common leak points.
Odds are you installed the head gasket wrong,as they'll leak coolant from between the block and heads if the gasket is installed wrong.Pretty common issue for alot of guys on their first cam/lifter job on a hemi
B
benny68
South carolina
Wouldn't the right side leak too? Going to pull it back down and check. Thanks
jws123
nj
the gaskets will be stamped left and right Left is drivers side right is passenger
Jeepwalker
WI
2012 Reg Cab, 4x4
Man... I always quadruple-check HG's before I bolt heads down. That's not one gasket to get 'wrong'. Hope your issue is something simpler (like a bad fitting).
