breezydun81
First I did that with the spark plugs to see if I still had ignition no antifreeze shot out of the cylinder and for the fuel on the spark plug it wasn't it was antifreeze but it was like a rust color a real light brown even when mixed with the anti seize ???If you pull a plug or two, ground those plug wires and crank it over - does it blow antifreeze out of the cylinder?
Something isn't adding up, usually something that leaks into all the cylinders will hydro the motor.
As well as show up in the oil as it will leak past the rings some.
For it to get into the plug wires from an internal leak, the antifreeze would have to push past the porcelain part of the plug.
Could it be fuel on the plugs??? And antifreeze on the exterior?
Sent from my moto g stylus using Tapatalk
