coolant temp gauge
macdaddy12
ga
5.7hemi
coolant temp gauge not working.
i replaced the sensor still nothing. i recalibrated the cluster and gauge moved. but still not working.
please help me to figure out what is going on. its a 2008 1500 4x4 bighorn 5.7
rzr6-4
nebraska
'09 2500
"i recalibrated the cluster and gauge moved. " Came up part way to warm but not hot temp and stopped moving or flickers between good reading and nothing?
Most likely some electrical issue.
M
macdaddy12
ga
5.7hemi
Well I figured it out myself. Went it to the ecu and set the coolant temp sensor to not present! Works perfectly! Go figure
M
macdaddy12
ga
5.7hemi
When should you change your coil packs ? I have 168000 miles never been changed. Still runs good but gas mileage suxs! Average 9 miles to the gallon
CorDog009
East Texas
I still have the factory coil packs at 174k miles. I wouldn’t change them unless you’re getting a misfire on a cylinder and it turns out to be the coil instead of the plug. I get around 15-18 mpg still. The cats could be getting clogged at that mileage and choking the engine a bit. Mine are there just for visual purposes only lol.
