Coolant Temp?
james stevens
Rancho Cucamonga
So Noticed My Truck Staying At 203-208
Then At A Stop Goes Up To 222-226
Then While Driving Drops Back To 203-208
Anybody Else Notice There Temp
Going That High Kinda Worried
Check to see if the fan run at a slow speed with the AC on. The cooling fan is electric, check for about a 100 Z-Case fuse attached to the battery terminal.2d4df9b4e236d45265731970817c46e9.jpg
whetrick1
Mines been doing that since brand new. They told me the new 19’s run a little hotter. They checked everything and said the fan was working normally. And I have turned the A/C on and waited a few minutes and the fan comes on and runs until I turn the A/C off.
Normal, nothing to worry about go eat a cookie and be happy.
Tim Garceau
Banned
Eagle River
2014 Sport Quad BSP
3.92 8 Speed 5.7 4X4
The mechanical fan is gone, they should have these 5th Gens getting 20+ mpg all day with improved aeros and weight reduction which is baffling. Once removed on the Gen4s mine saw +1mpg increase instantly.
On the plus side, tuners will be able to make big margins.
seabrook
seabrook
Black 2018 Night
5.7 3.92 anti slip
Idk anything about it but that seems high- interesting that it’s normal. An Efan should have a little more performance but since they rate them at the crank it’s all the same
joeagri
hpllywood, FL
My 19 does the same since new. Also the transmission runs hot but I am told it is also normal at 190 to195 deg.
whetrick1
Yeah I also noticed that mine runs a little hotter than my 2016 did.
crcraft
