Coolant temperature
JS1500
AR
Lately my coolant temperature has gotten up to 219* in city/short highway driving. It usually fluctuates between 204-219*, but 219* seems high. If it makes a difference, my truck is stock. Are these temps normal?
Yeah, way under what coolant boils at. You have the 8 speed? 2015?
What is your transmission temp when your coolant temp is 219? You guys with the 8 speed have a cluster **** known as the thermal bypass valve that is mated with your tranny. It is supposed to shut off and turn on yada yada to get the transmission at a perfect temp, but as we have seen on this forum it is horse ****. Some guys run religiously at 180f, and some others run religiously at 225f. I know the coolant heats the transmission oil in the name of fuel efficiency by heating the oil it makes it move faster and the epa says that is a good feature to have in a truck and FCA agreed, but I don't know if it can cool the transmission that would by default heat the coolant.
69GWC
Power Wagon
Spring hill, Kansas
2022 Power Wagon
6.4 Hemi, 8sp
Mine after 1.5hrs of pulling my 28ft camper.
Nothing wrong with 219 really imo.
And a pix of just normal driving temps.
Interesting, towing a 28' enclosed car hauler weighing about 8K lbs. The coolant was 215-220, trans stayed under 200 and the oil was 230-240 in 85-90 degree temps. Two different engine platforms, almost identical temps...it's like they engineered it that way [emoji44]
JS1500
JS1500
AR
My transmission runs anywhere from 176*-181*. When the coolant is higher the transmission is usually around 179*.
All is normal with your truck.
hualai
chile
Mine without towing ina 4.000 miles engine reads 224.6
