correct speed
DCKerns
jamestown ,ky
in search of a good tuner ,that will recalibrate my speedometer and delete shut off, shut down ! what is everyone using ? this is on 2019 bighorn classic with 5.7 hemi
You can use AlfaOBD to correct the speedometer along with other BCM configuration changes.
As for the "delete shut off, shut down" part I'm guessing your referring to the speed limiter of 105 mph you mentioned in another post. You'll need to have the engine tuned to eliminate the speed limiter(AlfaOBD can not do this).
joshhhh
