Couple of questions
alex_5_7
Hey guys im new to the forum and the world of trucks...I just got over my G35 and I decided I needed a weekend truck so I went with the 2014 V8 RAM black edition.I have a few questions to ask all you knowledgeable folk.
-Projector headlights
So the truck comes stock with projector headlights if you haven't noticed...I have never owned a pair of projectors and I was wondering if you can just change the bulb to HID's with a ballast? any specific type recommended?
-Lowering
I want a 2/4 Drop on the truck and i've head the mcgauphys 2/4 springs are pretty good but I was curious if I will still be able to tow heavy things?
-Muffler Delete
Will this hurt the hemi in any way shape or form?
loveracing1988
Clarkston, MI
-Lowering
-Muffler Delete
Yes you can buy aftermarket HID's, I have ran many ddm tuning kits but the last kit I bought is giving me all sorts of problems so I might go elsewhere next time. I believe H11 bulbs are still used as low beams but that could just be the quad lights.
No removing your muffler will not hurt the engine in any way. You may lose a little low end power but not much. There is actually a bolt on kit made by mufflex that moes performance sells that is a driveway installable kit.
quietpeen
2021 TRX
Hellcat
welcome to rf. get in contact with 0212353(retro shop) he can get you everything you need to do it
A
alex_5_7
another question,
Why does my truck only spin one wheel when i burn out in place? And how does one fix that? not implying im gunna do anything,just a question
BlkRamRt
SoCal
HEMI 5.7
another question,
why does my truck only spin one wheel when i burn out in place? And how does one fix that? Not implying im gunna do anything,just a question
you dont have posi. Buy a new rear end internals.
chrisb38002
Lakeland, TN
I will comment on the drop kit. I recommend the McGaughy kit, I had one on my 03 for over 9 years without any issues. I would suggest going with the deluxe kit so you get new front spindles. It keeps all the steering and suspension geometry closer to stock.
for towing, you can get an Air Lift air spring kit that fits inside the rear springs. This way you can add air when towing to keep things level. Check with Matt at Moe's Perforance, he can hook you up with what you need.
Fryekenn
