Cutting a piece out of the headlight
2013Ram1500
2013 CC 1500 4x4
I have the 2013 projectors and I want to put LED cubes in them as high beams (like in the picture below). However, there's that plastic piece that sticks out into that area and I wanted to know what ideas y'all have about cutting that piece out.
0212353
Vendor
Florissant, MO
2x 5.7L & 6.2L
dremel.
0212353
Vendor
Florissant, MO
2x 5.7L & 6.2L
oh........just a quick note............
The stock mounts for the projectors headlights are....well, weak, in my opinion. The stock bowl, with its OEM projector weighs in around 12oz. I've seen them break in shipping - wonder about that BIG pothole, eh? Add in FXRs (maybe) and its up to 1 lb 2 oz. Put a Rigid dually in there............almost 4 POUNDS. Thats a lot of weight....
We will not do this modification because of that. ;)
argray90
NW Burbs, IL
That would look cool but damn are those lights expensive to be cutting.
0212353
Vendor
Florissant, MO
2x 5.7L & 6.2L
its just a shroud.......2 little parts 1" long, 10 seconds to cut then sand, done.
2013Ram1500
2013 CC 1500 4x4
I hadn't even thought of that... but I will definitely take that into consideration. If I decide not to do it then I'll probably just save them to put into the rear bumper as back up lights.
jsl6v8
Virginia Beach for the moment
2013 Ram 1500 HFE RCSB
3.6L V6 And proud.
those headlights look awesome, haven't seem that ram projector before either, is that how they come on the new 14s?
2013Ram1500
2013 CC 1500 4x4
No, that was custom made on that set but that would be sweet if they did come like that
jsl6v8
3.6L V6 And proud.
JJ's work or someone elses? JJ if I end up getting a truck when I get to Hawaii you can expect a call, whether these are yours or not, please don't kill me on shipping.
2013Ram1500
2013 CC 1500 4x4
Someone elses
2013Ram1500
2013 CC 1500 4x4
Hey JJ I have another question. How can I make that turn signal piece black like that? I emailed the guy and he said it's translucent but didn't tell me how he did it and has yet to reply to me again.
Also, I decided against the LEDs. I'll probably just order some HIDs from you for my lows instead.
0212353
Vendor
Florissant, MO
2x 5.7L & 6.2L
We just use a "tint" mix of our gloss black.......translucent, spiffy, but damnit thats dark and....well.....I'd want to see 'em lit!
if you are going to open them lights.......PLEASE do a retrofit on the projectors. You will be impressed!
2013Ram1500
2013 CC 1500 4x4
They're already opened up and painted. I'm just waiting to put them back together because I keep wanting to do more lol. What exactly do you mean by retrofit?
0212353
Vendor
Florissant, MO
2x 5.7L & 6.2L
pull the stock projectors and put FXRs in there. You've already got the hard part done........do the easy part that gives you awesome output
Check my drive along out - http://www.ramforum.com/f41/video_drivealong_my_lights-41602/
Cost? $350. You get the FXR projectors, retrofitting plate (makes the install nice), 35W D2S ballasts, XB35 D2S bulbs, and wiring for your truck (full harness). If you are already going to get HIDs, this is about 180 more than that, and will BLOW away the stock projectors.
0212353
Vendor
Florissant, MO
2x 5.7L & 6.2L
no, but 90% was. I do have some commentary during the video, I let ya know when I go to highs ;)
2013Ram1500
2013 CC 1500 4x4
I hear it now that I listened to it with sound on my computer. I was on my phone last night and didn't want to bother anyone else so I had the volume off. Do you have any comparisons between the stock projector with HIDs and the FX-Rs?
And for the cost you said $350, but I was looking at the website and it says $640. Is that if I send the headlights and you do the work?
0212353
Vendor
Florissant, MO
2x 5.7L & 6.2L
350 is the parts needed for your build there.
640 is the parts, supplies, labor, shipping and any other fun I have when doing the retrofits here.
Nicholas Lozano
