Cyclic (sine wave) Noise when driving 72+
FLPetersen
OH
So we took the truck on the first big trip these past 10 days, with Covid and all, and my short work distance, I rarely get 70+
Halfway from Lima, OH to Cincinnati I begin to hear a cyclic sine wave pattern hum. It starts soft, then grows loud (at times very) and then dissipates, and repeats barely 3-5 seconds between end and restart. It happens at or near 72+, sometimes hitting the gas will stop it for a short while, other times taking foot off gas will, but it returns.
It almost sounds like that reverb hum you get behind the engine when accelerating before the gear shifts. Hopefully this makes enough sense to someone.
I had the joy of hearing this for 10 day through the state of Tenn, until our return last night.
I did a bit of Googling, and saw someone else with a similar issue. The thread (elsewhere) had no resolution, but one person said to use the Gear Limit and shift it out of automatic to 8 to see if the sound disappeared. It did not. They then said try 7. At 7 it stops. At 72 the engine of course picks up sound as the truck is pushing the gear limit, but the cyclic hum vanishes.
I cannot believe this is normal, but I'm not sure what it might be and how serious it might be. Looking for advice. It is however not a pleasant driving experience.
mikeru
Super Moderator
Moderator Supporting Member
2020 Limited
Hemi 5.7L non-Etorque
That's not something either of my trucks do, and definitely not normal. I'd take it in and take a tech out to recreate the issue. They can't fix anything if they can't recreate it. But if you can reliable recreate it they should be able to diagnose the problem.
FLPetersen
FLPetersen
OH
After a lot of digging and searching, I was given this: TSB 08-056-19
https://www.carcomplaints.com/Ram/1500/2019/tsbs/tsb-08-056-19-rev-a.shtml
There was also a post on ************** from a gentleman reporting nearly word for work what I was experiencing.
He starts as "The first week I owned my truck, I took it to Las Vegas. Cruise control set, open road, everything seemed just fine. Until the droning started. Right at 72 mph, lessening at 71 or 73, gone at any other speed. It scared me, but then it went away. Then came back. Very consistently." and then goes on to detail is diagnosis and dealer issues getting this resolved.
If I am to guess, this is it.
mikeru
Super Moderator
2020 Limited
Sounds like you at least have a lead on getting it figured out. Good luck and I hope you get it taken care of.
